Case 930
Randy Unger
06-16-2007 11:26:34
Weve got an old Case 930. Bosch pump SD C2 A22638. First of all, how do I turn the pump up, for more power? Also, i want to put a turbo on it. However, the manifold is broken off towards the end, and being cast, I cant really weld the flange to it I need. Did Case offer a turbo on a tractor with the same 401ci engine that I can use the manifold from? Thanks.
Brad Gyde
06-23-2007 07:46:42
 Re: Case 930 in reply to Randy Unger, 06-16-2007 11:26:34
I have a 1962 930, M&W turbo, pump turned up a little bit, Has been this way since the last owner bought it in 68,and he said he bought it that way. unsure of exact hours, tach is broken, but other than I had the injectors done when I bought it and it needed head gaskets, and since the turbo went out and has been replaced, but it don"t seem to be hurt 1 bit (Last overhaul was in 79 with the reciepts that came with it)
I guess the point I am making is we all have opinions, so do what you think is right... You may end up with what you are looking for, or you may end up with scrap iron in the end.
junk yards are full
06-18-2007 19:09:36
The junk yards are full of case X30's with turbos.
Sell the good running 930 and buy a bigger tractor, Why tear up a good 930?
Randy Unger
06-18-2007 20:08:35
 Re: Case 930 in reply to junk yards are full, 06-18-2007 19:09:36
By the replies its clear that people arent reading the original. Its not a good tractor, ragged worn and retired. Im not putting any money. I have a pyro, boost gauge, I have a turbo for it, and I want to turn up the pump. I know what to watch for, I already have a bombed dodge diesel. Thanks for the replies.
630crazy
06-21-2007 08:59:29
 Re: Case 930 in reply to Randy Unger, 06-18-2007 20:08:35
You are correct Randy... Back to your original question. If no one here knows how to turn up your pump, you might try a local injection pump rebuilder. I don"t know if they would want to divulge the secret, but it might be worth a shot.
BTW What are you planning to do with the old "9"? Are you going to start "pullin" with it?
that is just the point..
06-20-2007 00:22:39
If the engine is worn out then re-build it. If that is too much money sell it running..
you will take the time put on a turbo and wear it out faster... end game junk...
Spend your time and money getting a bigger tractor with turbo, and bigger cooling system, bigger oil filter, bigger bottom end....
When they built the tractor if it would have lasted with a turbo they would have come that way from the factory....
A 930 will run for thousands of hours but not for thousands of hours with a turbo...
Grandma is slow and she is old lets give her a dose of steroids and see if she can play pro-ball????
The cheap way out is the most expensive...
KY Jim
06-18-2007 11:23:05
Yeah, more fuel +more air=more power +HEAT, have to adjust timing and REALLY watch PYRO/Manifold Pressure gages. Bigger radiators and oil coolers very good ideas. KY Jim
SDLoy
06-17-2007 13:58:21
 Re: Case 930 in reply to C. Amick, 06-16-2007 11:26:34
If you add air without more fuel you will create a lean condition that will definitely create more heat. A turbocharger is part of a fuel system. The system must be engineered to match and complement the pieces. A mismatch can be disastrous and expensive. Loy
glennb
06-17-2007 12:01:01
advance the timing, the fuel entering early will act as a cooln agent, im running 350 hp out of a 6030 JD and temp is not much of an issue( wouldnt let just anybody run it though) does start harder though.
Randy Unger
06-17-2007 12:28:26
 Re: Case 930 in reply to glennb, 06-17-2007 12:01:01
So how do I go about finding directions for turning up pump and setting the idle. And I dont understand the last part. Think of a diesel truck. The more air you can pour in faster the cooler it will run. We are not talking about a wood fire here....
how many engines have you
06-20-2007 00:36:45
 Re: Case 930 in reply to Randy Unger, 06-17-2007 12:28:26
It is just physics... the more air the hotter the fire... have you used a cutting torch? More O2 hotter fire NOT RUNNING COOLER...
C. Merchant
06-16-2007 12:14:10
The case 930 was a "Powercell" engine and as such very effecient. This design does not lend itself to turbo adaptation as well as the direct injection models. It has benn done but the benefit is marginal and you relly have to watch the heat. As to the manifold, if you can get the parts yoy wanr and putit in the Bar-B-Q, get it good and hot you can do a good job of brazeing the flange. My suggestion nwould be to find a 70 series engine. I may be wrong, but LOL!
Randy Unger
06-16-2007 13:26:17
 Re: Case 930 in reply to C. Merchant, 06-16-2007 12:14:10
Well Im not putting any money into this tractor-Ive already got 2 trucks that are money traps. How would the turbo addition cause a heat problem?
630crazy
06-16-2007 15:37:58
 Re: Case 930 in reply to Randy Unger, 06-16-2007 13:26:17
What happens when you blow on hot coals??? Same thing inside the combustion camber... more oxygen, more fire, more heat. Especially if you turn the pump up, then you are feeding more fuel to fire. The 930 heads are prone to cracking and do not like to get hot. Our 1570 had a pyrometer on it and in heavy clay on a hard pull you could easily and quickly climb into the 1200 - 1300 degree range.
