930 Crankshaft with spun rod bearing
Christian
06-15-2007 09:01:00
Are there any good reasonable machine shops in or around central Missouri to get a crank built up and turned down. Some shops around here wont do diesels for some reason, or cant build the crank up. If there is anyone with a 930 diesel Comfort King 8 speed crankshaft and rod that they wouldnt mind getting rid of please let me know.
Nedd
06-15-2007 09:13:00
 Re: 930 Crankshaft with spun rod bearing in reply to Christian, 06-15-2007 09:01:00
Should be the same crankshaft as a 1030/970/1070. to help widen your search.
Camboted
06-17-2007 04:59:58
 Re: 930 Crankshaft with spun rod bearing in reply to Nedd, 06-15-2007 09:13:00
Also, LP Gas uses the same crankshaft.
