580 case oil leak
sam un ont
06-14-2007 07:53:33
i have an older 580 case that has recently developed an hydraulic oil leak from the weep hole at the rear of the engine on the bellhousing. any help and ideas as to cause and repair are appreciated sam
Jim B
06-15-2007 06:49:43
 Re: 580 case oil leak in reply to sam un ont, 06-14-2007 07:53:33
Is your 580 a 580CK (Construction King)? Is so, it sounds like you have a manual clutch with mechanical shuttle (reverser)... not a power shuttle which uses a torque converter. The reason I say that is because the manual clutch has just such a "weep hole" where as the power shuttle has no such hole as the case is sealed and filled with hydraulic fluid for the converter and power shuttle. Oil that leaks from this weep hole can be either engine oil from the rear main seal leaking or tranny oil from the mechanical shuttle input shaft seal leaking. The weep hole is open to the oil-dry clutch chamber.
