Exh/int Gaskets
tomturkey
06-13-2007 07:15:59
CIH doesn't have intake exhaust gaskets for 400(411) gas. Who carries these? thanks gobble
shawnspeed3
06-13-2007 09:14:30
 Re: Exh/int Gaskets in reply to tomturkey, 06-13-2007 07:15:59
Is the 400 gas/411 the same A-251 engine as the gas 730 series tractor???if it is ,you might want to see if your local NAPA dealer can order them through clevite, the gasket kit I ordered thru napa had them in it , but no metal flanges , which I had to make my self by making a die and swageing some exaust tube to the right size....what a PIA that was ....most likely a rotted flange is causing your leak...Good luck Shawn
INCase
06-14-2007 04:52:05
 Re: Exh/int Gaskets in reply to shawnspeed3, 06-13-2007 09:14:30
I believe the big 400/700/800 had different sized exhaust ports than the 730/930 gas, NAPA should be able to look up the older gasket sets too. They are about $10 each at the Case dealers. Ferrels for the 400/700-800 are easy to make. get a 6inch piece of exhaust pipe from the autoparts store (double check the diameter, and cut off 1/2inch pieces on a lathe. The trick is cleaning the old one out of the manifold.
