Swather problem
Oshbrg
06-12-2007 18:53:09
I have a Case 955 self propelled windrower (swather, haybine, whatever you would like to call it) and it works pretty good.... for awhile. After it runs for around one hour, it acts like it is running out of gas. Plenty of gas in the tank. No dirt in sediment bowl, and a clean fuel filter. One you let it sit about 15-20 minutes, it good for around 5-10 minutes again. Let it sit overnight, and it will run an hour or so again. It has the case engine. I wondering if its maybe vapor lock, or something like that. Any ideas?
Thanks much!
Mike
SDLars
06-13-2007 09:13:00
 Re: Swather problem in reply to Oshbrg, 06-12-2007 18:53:09
My little 444 Case garden tractor with a Kohler 14 hp acted very similarly. I limped through last season with it by just blowing into the gas tank (guess it pushed some fuel into the carb) but replaced the fuel pump this spring and now it works perfectly. Sounds like a fuel problem to me.
GEOMO
06-13-2007 04:47:17
I DON'T KNOW ANYTHING ABOUT THE 955 BUT, IF IT HAS A COIL I WOULD CHECK IT IF YOU DO NOT FIND THE GAS PROBLEM. BAD COIL ACTS THE WAY YOU DESCRIBED.
Roger in Iowa
06-12-2007 19:19:09
Is the gas tank vented? When you loosen the gas cap do you hear air rushing in? When you loosen the cap does it run for awhile again?
Carefully run with the gas cap loose! The vent may be plugged.
When it stops remove the plug in the bottom of the carburetor (careful of fire) and see if gas runs out or not.
Roger in Iowa
Oshbrg
06-12-2007 19:24:21
 Re: Swather problem in reply to Roger in Iowa, 06-12-2007 19:19:09
The tank having a vaccum is a great possiblity!!! I will definately check that out. I never even thought of that. It would make sense. When I hold the choke after it starts acting like its running out of gas, it helps a bit.... but not a whole bunch.
Thanks!!!!! !!!
630crazy
06-14-2007 17:22:43
 Re: Swather problem in reply to Oshbrg, 06-12-2007 19:24:21
Sounds like a plugged vent, but if the vent doesn't pan out, check inside the tank for debris that might be floating around. I had an old H that did the same thing, it would run for a while, then would start not wanting to run w/o the choke on.
Did you say you have a sediment bowl and an in-line filter? Somewhere in this forum it was mentioned that you shouldn't use both a sediment bowl and an inline filter. Don't remember why, but I just remember reading it.
