Case 530 serial number
Jon in Iowa
06-11-2007 08:46:40
I have a Case 530 gas without a serial number plate.
Does anyone know if it can be referenced from the block number?
Who would have these records?
thanks,
dbock43
06-11-2007 18:40:35
 Re: Case 530 serial number in reply to Jon in Iowa, 06-11-2007 08:46:40
My 530 was also missing the serial number like a lot of them for some reason. Luckly, I was able to go though some of my grandpa"s loan records and I found the serial number on a loan. There are three breaks in the parts manuals for the 530. If you look at the parts manuals online it could give you an idea on which break you have based on your options.
Rob Baird
06-11-2007 15:43:03
HI I have an orphan 530ck Does your tractor have an eagle hitch or 3 point Eagle hitch was discontinued in late 62 or early 63 Mine has the eagle hitch so I call it an early 60s tractor I like it and works well for what I do with it
JGarner
06-11-2007 10:21:52
I have the same problem with my 630. The serial number tag is on the left side panel just like your 530. Over the years these panels are removed and never replaced as they are non functional. Your serial number and mine are probably either sitting on this panelin the corner of a shed somewhere or thrown out behind that shed to rust.
The engine block number has nothing to do with the actual tractor number ubfortunately and unlike the older VA, S, D, and LA tractors the tractor serial number is not stamped on the engine to transmission flange.
