New to Case
Jeff McBride
06-10-2007 19:01:10
I guess you could say I am new to Case. I own a 4010 and 1010 Green and yellow and a H,M,and Super M Red. I have been offered a Case SC for around five hundred $. I know it is a good buy cause it runs and has been painted, though I haven't looked at it up close. I guess my questions is what to expect out of an SC what kind of HP and did they have threepoint if not how hard to put one on. What do I need to look for when I go look at it. Are they hard to steer Are they hard to work on. You know the same questions ask on these forums at least three times a week.
Thanks
Jeff
C. Amick
06-11-2007 09:21:57
 Re: New to Case in reply to Jeff McBride, 06-10-2007 19:01:10
Unless it is one of later ones built, it likely has a hand clutch similar to the older JD's. The Case clutch is a wet clutch, however, that is lubricated by engine oil. It has about the same horsepower as your Farmall H. They are not hard to steer or work on. If it has what is called a "hydraulic lifting bail", it can be converted to a 3-point hitch, but it won't be live. Drain a little oil out of the pan to see if there is any coolant in it. The most common place for the block to crack is just behind the carburetor. This crack is not harmful.
Walt Davies
06-10-2007 22:26:39
Draw bar HP is 15 belts pulley is 31. If it has one they what is called an Eagle hitch a lot like the 3 point and will work on most things.
Walt
TimBinWV
06-10-2007 19:14:03
The SC is an excellent tractor...especially if it's a foot-clutch model(53/54)...not sure of the HP,but would guess it to be 45 or so....easy to steer,with a narrow front,but not sure w/a wide front...$500,running condition,will make you wanna part with all things red,green or yellow.....
