va series front mount hydraulic pump
watsonsgotit
06-10-2007 18:45:02
I am gathering parts to put my 48 VAI together. I have two hydraulic pumps for it. I just noticed that they both have different casting numbers. One came from the VAI and the other a VAC. The casting numbers appear to be VAI VT-519?
VAC VT-608. Can someone tell me what the difference is in these pumps. I noticed that one pump is physically thicker than the other. Are they the same or different? In knowing that the transmissions are geared differently, I am wondering if the pumps are the same way. Could the industrial pump be set to pump more fluid or pump faster?
