970 case
goomba
06-10-2007 18:42:16
I have a chance to buy a 970 Case C&A that has a hole in the block just under the injector where a loose rod whacked it. Without dropping the pan I can see that the cap is gone off of the rod simply by looking throught the hole (which is about 1 inch wide and 4 inches long). I've known this tractor for 30 years and it's not been abused. Owner says he's going to sell it. What problems should I expect to run into inside the engine if I buy it? I'd love to repair it and use it in my hay operation. Also, what type of air conditioner compressor did Case use on these model tractors?
dboll
06-11-2007 13:20:05
 Re: 970 case in reply to goomba, 06-10-2007 18:42:16
first off check the crank, if it is trashed i would consider finding a used 401 or 451 to install, should be able to get one for $1800 to $2000, Case retrofits better than most to R134 due to the condenser size, we had a 970 for many years and spent very little on it, very dependable tractor.
justanothercase
06-11-2007 10:07:21
If you get the block fixed i think you would want to major the engine sleeves,pistons,all new bearings and seals. Case used a york ac pump on those tractors.
