700 800 LP head manifold stud help
INCase
06-10-2007 17:03:16
It looks like the studs for the manifold clamps on the 800LP heads (A8500) are smaller threads than the gas or later 30 searies. Is this correct and what size should they be? Does anyone have a set they could part with? Thanks.
INCase
06-12-2007 19:24:07
 Re: 700 800 LP head manifold stud help in reply to INCase, 06-10-2007 17:03:16
got them in better lighting. Looks like they must be the same as the 800/730's ect. Need to get a tap and clean them out. They must have used lock-tight in them and its goofed up the 1st couple of threads so the studs won't even start. Thanks for the help.
Gene Dotson
06-10-2007 17:41:47
The manifold clamp studs are the same for all 700 and 800 engines, both gas, LP and diesel... Gene
INCase
06-11-2007 11:00:07
 Re: 700 800 LP head manifold stud help in reply to Gene Dotson, 06-10-2007 17:41:47
Thanks Gene, I thought they should be. These LP heads actually came from a 600LP (sorry should have mentioned that). Were the 400/600LP heads (or gasers) different? I would guess they were not BUT darn"d if the 800 gas or 730 gas studs will go in. Thanks again.
Jim B.
06-11-2007 20:11:56
 Re: 700 800 LP head manifold stud help in reply to INCase, 06-11-2007 11:00:07
We broke a manifold stud on our 800 Gasser a couple of years ago and the Dealer couldn't come-up with a replacement. So, we simple made one from a too-long course thread grade-8 bolt. Cut off the head to make it the right length and die-cut fine threads for the manifold clamp and nut.
Cost: $1.29
