case 930 clutch
izzac246
06-10-2007 10:03:57
please can someone tell me how to adjust my clutch in my 6 speed 930,i have the manual but not the adjusting tool plus the manual is very vague in description
thanks for any help
COWBOY
06-10-2007 18:16:20
 Re: case 930 clutch in reply to izzac246, 06-10-2007 10:03:57
You can use a small forked bar to pull the pin up and rotate the collar clock wise to tighten clutch. Access is through inspection plates on either side of the clutch housing
Camboted
06-11-2007 05:02:57
 Re: case 930 clutch in reply to COWBOY, 06-10-2007 18:16:20
We set dozens of them and have never had the proper tool. A pair of needle nose pliers, work well, especially the bent nose type. I've even done it with my fingers.
