2670 door,
Kirk in Ks,
06-10-2007 08:39:52
how do I fix this door on this 2670, it scrapes on the left front fender, then it shut's but kinda hard, it's pinching the back lower door seal?
I give up.
Jim B.
06-11-2007 20:19:54
 Re: 2670 door, in reply to Kirk in Ks,, 06-10-2007 08:39:52
Hey Kirk, You've been talking about fixin' that door since last fall. Get the penetrating oil into those hinge pins and start wrenchin' and hammerin' until it fits OK.
Have you been able to job-out your 2670 for some field work this spring, as you had intended?
rcgrey
06-10-2007 14:45:06
Kirk Make sure hinge pins are not rusted tight when they get rusted hinges will bend take pins out and remove door bend cab hinge to adjust front or back using a large hammer (careful moving hinge a small amount changes bottom of door a lot. Bend hinges on door with large adjustable wrench to adjust in and out hope this helps. JIM
