UPDATE: VACs in the woods
Soldier Tom
06-10-2007 07:00:25
Yall may recall around Christmas I found two old VACs in the briars across the road from my farm. Well, I opened them up last week. Pulled the sheet metal off, and the head off both of em. The 51 was in BAD shape. Head rusted up solid, #2 cylinder sleeve rusted plum through, and a myrid of other things. The exhause manifold was in real good shape tho.
The 52 was only lightly stuck on #3, and had been soaking in diesel since Jan. (Don't know if it helped or not, but..) I hooked the crank up to a engine hoist and put just a bit of pressure on it, and whacked it a couple times with a block and mallet, not all that hard either, and the thing come loose. There was a little rusty spot that cleaned up with just a little sand papering. Took the head to the machine shop to do a basic valve job, and clean up on it ($50).
Then my week of Leave was ended. I am going back in July and maybe I can get some more done then. I will post some more pics over in photobucket and try to get them linked in today sometime to this thread. (If I can remember the secret handshake).
~Walk in peace
Soldier Tom
Soldier Tom
06-10-2007 08:09:58
 Re: UPDATE: VACs in the woods in reply to Soldier Tom, 06-10-2007 07:00:25
third party image
After a little cleaning up,I rolled over the crank handle a few times and dogged if oil didn't come out the feed hole! Left a coat on all the cylinder walls until I get it back together. Maybe this will not be such a hard thing to fix after all. (Even for a JD boy like me.)
~Walk in peace~
Soldier Tom
Walt Davies
06-10-2007 10:37:31
 Re: UPDATE: VACs in the woods in reply to Soldier Tom, 06-10-2007 08:09:58
congratulations Tom we expect to see a running tractor soon,
Walt
Rex Maddy
06-25-2007 05:09:18
 Re: UPDATE: VACs in the woods in reply to Walt Davies, 06-10-2007 10:37:31
Hello, I have a 1954 CASE VA that is in good shape.
It was overhauled about 5 years ago (hardened valves) and has new rubber all around. I had trouble with the rear end and gears shifting, so I put a VAC rear end on it. The old rear end goes with it for parts. The paint job is decent, but not show quality. Runs great. I am moving and have to sell. What price range should I ask for it?
Rex Maddy
Martinsville, IN
