Firing order
Jared Helvie
06-08-2007 07:17:01
I just picked up a 1941 case sc and the spark plug wires were not connected to the spark plugs. Im just wonderin if you guys can tell me which wire from the distributor cap goes to which cylinder.Thanks for any input.
r w schultehenrich
10-22-2007 12:17:56
 Re: Firing order in reply to Jared Helvie, 06-08-2007 07:17:01
for case 310g and #1 on cap
Gene Dotson
06-08-2007 10:33:22
Jared;
# 1 cylinder is front next to radiator. Look at magneto from rear. Install #1 wire at 10 o'clock, Install #3 at 2 o'clock, install #4 at 4 o'clock and #2 at 8 o'clock. This should get you going. Wouldn't worry about exact timing till it is running. If the mag hasn't been off, you will likely be alright... Gene
gary tomaszewski
06-08-2007 08:02:18
Can't be fixed, so I'd be willing to take it off your hands for a parts tractor!!! Seriously, need way more info - mag or distributor, has either been remove, do you know how to time engine, lots more than just plugging wires in and starting. A good shop manual is your best friend. Good luck with your SC they are a great tractor.
