case 730, 1960.
Ringer
06-07-2007 18:45:38
Im looking at buying this tractor from a local where I live. it has loader but no 3 pt, my question is there a way to find and put a 3 pt on this tractor
INCase
06-08-2007 05:24:46
 Re: case 730, 1960. in reply to Ringer, 06-07-2007 18:45:38
If its a 1960 it would be an "eagle hitch" model. The 700,800 and 830"s should bolt right on. I"m not sure what parts are interchangable on the comfort king 3pt hitch units IF any. You"ll need the rock-shaft unit that bolts on top of the transmission, the lower mounting bracket the the lift cylinder. This mounts with the left drawbar brakets. A lift cylinder (a few options here but the Case one would fit best) a set of lower lift arms (I would buy regular 3pt arms instead of the eagle arms from a junk tractor or a new set from a tractor supply place) a pair of lift links (again junkers or I think you can find generic new ones) and replumb one set of hydraulic lines to the lift cylinder. Our local salvage yard has what you need. You could figure about $200 to $400 (more if you want the Eagle hitch clips too). I just sold some of these lower parts myself from a 1961 730. Good luck.
Camboted
06-08-2007 04:38:31
All the hitches are basically the same from the 400 through the 830. At some point they changed the bolt pattern on the rock shaft. I know the 400 is slightly different than the 830.
Jim B.
06-07-2007 19:39:39
Sure... Salvage parts are certainly available for most any tractor including the 730. The 3-point system is simply a bolt-on item.
Others should confirm this, but I believe a 3-point system from several Case models will fit. An 830 for sure and perhaps others.
Check out the Classified Ads available on this Website. The link is at the upper left of this page. If you don't see one For Sale, then place your own "Wanted" ad.
