Vac plow question
Hand Crank
06-07-2007 13:56:54
I located a 3pt 2 bottem plow,made by Dearborn Farm Equiptment.Will this plow work on my 1950 vac with the eagle hitch?It looks like it will. Just wondered if anyone else has used a plow like this on the eagle hitch system.Any help greatly appreciated, Don.
max46
06-09-2007 18:43:57
 Re: Vac plow question in reply to Hand Crank, 06-07-2007 13:56:54
I have a 51 vac with a eagle hitch and my buddy had a dearborn plow, it fit on good and the only thing you have to do is set the tilt angle to make it dig in, I removed my down stop bolt so that it would allow the arms to drop all the way down, if it has colters be careful that they don't hit the hitch bar but mine didn't hit and it really plowed good, hope this helps,
Rex Maddy
06-25-2007 05:26:56
 Re: Vac plow question in reply to max46, 06-09-2007 18:43:57
Hello, I see you have a VAC. I have a 1954 VA and I have to sell because we are downsizing. It is overhauled, has new rubber all around and a decent paint job. The rear end was swapped out to a VAC rear end due to some shifting trouble I was having. The original goes with it for parts.
What do you think I should ask for it. It seems that you don't see many VA tractors at the shows around here. The VAC and others in the series are more common.
Rex Maddy
Martinsville, IN
