vac eagle hitch
Rags
06-05-2007 18:04:36
The eagle hitch on my 42 vac won`t hold in the raised positon,also very spongy.Back of tractor is covered with hyd oil.Never got into this before.Where do I start? Also blows oil out of breather.Thank`s Don
Rex Maddy
06-25-2007 05:22:59
 Re: vac eagle hitch in reply to Rags, 06-05-2007 18:04:36
Hello, I have a pretty nice 1954 CASE VA for sale. It has been overhauled, has a VAC rear end replacing the original due to some shifting trouble. The original goes with it for parts.
What do you think I should ask for it. The paint job is pretty good and it has new rubber all around.
Rex Maddy
Martinsville, IN
Joe (Wa)
06-06-2007 00:35:48
Eagle hitch was factory installed on tractors 1949 & later. If your hitch looks like the one in this picture, the piston in the cylinder under the seat leaking bye into the rock shaft will cause all the symtoms you describe.
Piston is either the cup or o-ring seal type. Cylinder could be scored, just have to open & check. Control valve can be leaking also but that doesn't cause breather weep like a piston seal leak does.
Joe
Rags
06-06-2007 04:15:06
 Re: vac eagle hitch in reply to Joe (Wa), 06-06-2007 00:35:48
Hi Joe,
I was in to much of a hurry.My vac is a 1950,not a 1942.I do have the eagle hitch.Just like the picture.Thank`s Don.
