David Brown/Case 885g temp gauge and sending unit
Jamey
06-05-2007 14:36:03
I am looking to find a temp gauge and sending unit for my tractor. Can anybody help?
steven meckstroth
06-06-2007 15:46:47
 Re: David Brown/Case 885g temp gauge and sending u in reply to Jamey, 06-05-2007 14:36:03
Have you checked with your local Case/IH dealer? The on-line parts book shows that the same gauge and sender were used on the gas and diesel models.
Jamey
06-06-2007 19:17:53
 Re: David Brown/Case 885g temp gauge and sending u in reply to steven meckstroth, 06-06-2007 15:46:47
Yes, I was just hoping to find one cheaper. Total cost will be about $135.00. Thanks for the response
steven meckstroth
06-06-2007 19:22:13
 Re: David Brown/Case 885g temp gauge and sending u in reply to Jamey, 06-06-2007 19:17:53
If you check the Case on-line parts book, it lists the AC-Delco number also. You could check with an AC-Delco auto parts house.
Jamey
06-07-2007 14:41:42
 Re: David Brown/Case 885g temp gauge and sending u in reply to steven meckstroth, 06-06-2007 19:22:13
Thanks, will do. How do I get to the Case on-line parts book?
steven meckstroth
06-08-2007 15:11:14
 Re: David Brown/Case 885g temp gauge and sending u in reply to Jamey, 06-07-2007 14:41:42
Go to:>Link
In>Link right hand column, click "search for parts"
On lower right had column of new page, click "Begin your SEARCH for PARTS right here!"
This will open a separate window. Type in model number and click search. Select third open, 885 Selectamatic.
The numbers you are looking for are:
temp gauge AC Delco 7966282
sender, temp AC Delco 7966281
Jamey
06-09-2007 09:04:46
 Re: David Brown/Case 885g temp gauge and sending u in reply to steven meckstroth, 06-08-2007 15:11:14
Got it, Thanks for all the help
