570 Distributor
rrbusb
06-05-2007 08:28:43
570 was running fine mowing, then stopped to talk to a neighbor and left it at idle. Got back on ran about 20 yards and quit. Have replaced coil, points, cap & rotor, but seem to have alot of play with the rotor, shaft seems to move just short of a quarter of a turn. Will run now, but POORLY. Haven't worked up the courage to pull the distributor yet, to see if there is a key that needs replaced. Suggestions (yeah I know, hire a real mechanic.....)
CENTAUR
06-05-2007 11:06:58
 Re: 570 Distributor in reply to rrbusb, 06-05-2007 08:28:43
Where do you find a real mechanic that can fix a distributor? Find the exact brand and part number.Is the Quarter turn of the shaft the ( normal) range built into the mechanical advance?I am guessing thats it.Please post again and yes I do not even know what a 570 looks like. CENTAUR
