new clutch
reg388
06-03-2007 09:15:42
I put a new clutch in a 570 case diesel,now it won"t turn over. I failed to have my shuttle shift in neutral and its stuck also. please tell me I can fix this with out respiting the tractor. Thanks reg388
Klyde
06-03-2007 16:10:29
 Re: new clutch in reply to reg388, 06-03-2007 09:15:42
Did it slide all the way together or did you draw it together with the bolts?? Same pressure plate or a new one?? If you closed it up with the bolts the splines may not have been aligned and you will have to resplit to replace the plate or the cover with the center warped out of it. Some new covers don't fit inside the bell housing without a little grinding inside the bell housing. (timing boss) This will lock the engine but not the shuttle shift. If the shuttle shift worked ok before, sounds like things were not aligned properly and maybe pushed the shaft back into the tranny along with bending the cover and the plate. Hate to sound like Mr. gloom and doom but I think your respliting.
reg388
06-03-2007 16:56:10
 Re: new clutch in reply to Klyde, 06-03-2007 16:10:29
I checked it out and I think you're right. Dam the luck, I pulled it together with the bolts and the tractor came together very easily. thanks reg388
reg388
06-03-2007 16:55:54
