Case 200 triple range
franmach
06-02-2007 11:03:22
The handle to my triple drive gear box came out. Looks like a pin sheared, and the little half moon clip (forgot what they're called) is somewhere in the box. It was in low when this happened. I can't get the top of the gear box more that a half inch off before something holds it down. Any advice as to what to do?
BarryfromIA
06-02-2007 15:06:55
 Re: Case 200 triple range in reply to franmach, 06-02-2007 11:03:22
You have to get the shifter rail back to neutral. Use a flat bar or screwdriver or what ever. Once you get get every thing in neutral it lifts right off. Not an easy job but, it is cheap to fix. The later tractors did not have triple range because of this problem
franmach
06-02-2007 17:37:46
 Re: Case 200 triple range in reply to BarryfromIA, 06-02-2007 15:06:55
Thanks Barry.
