No Grass for the eagle hitch
JRT
06-01-2007 22:08:39
Probably only you old Case owners would understand this situation. When Eagle hitch type tractors were new, they had a rope tied to the little hinged type locks that held the impliment in place. The idea was to set on the tractor, pull the rope , back up and hitch up without getting off the tractor. Well the idea was good but when the lock got a little ware on it, it didn't happen. Then you had to get off the tractor, scoot the latch back and back up to the impliment. Just as you started to back up , the latch would fall back down blocking the hook and you got back off the tractor and started the process again. I learned a long time ago that a solution to this problem was to grab a wad of grass and stuff it in behind the hook so it could not fall back and it made the job much easier. Well now, here is the delima this summer. Today I was hooking something up in a harvested hay field ( 2 weeks ago) and there was no grass to grab. I had to walk 200 feet to the edge of the field, and still barely found enough grass to do the job. Now folks, That is what I call Dry Weather.
Joe (Wa)
06-03-2007 11:23:49
 Re: No Grass for the eagle hitch in reply to JRT, 06-01-2007 22:08:39
I'll have to give Roger a plug here. I got 4 of his flat springs and they work great on my 300 hitches. I think they fit many of the other number series tractors also. Original p/n is 09228 AB, cross-ref p/n A27670.
[email protected]
Joe
RogerCase300
06-02-2007 17:13:49
Those flat springs work and Case still have them but I've heard the cost is about $12. a piece. I make them now out of spring steel, same gauge and I" wide like originals, $4. ea. Picked up a bunch of the flat spring steel at an auction, get some use out of it. Roger
Bernsy MN
06-02-2007 09:38:03
I keep a bungie cord for each side to use when switching implements, just have to make sure to unhook them from the latches after the implement is in place!
PhilcaseinWPA
06-02-2007 02:56:56
I take a small stick or even a stiff straw of dried grass or weed and put under the hook to keep it open. The springs to hold the hooks open have been gone for a long time.
Phil
BarryfromIA
06-02-2007 15:49:44
 Re: No Grass for the eagle hitch in reply to PhilcaseinWPA, 06-02-2007 02:56:56
I believe that there was a flat spring that held that latch up or down. The remains of it is probably still bolted to the hitch arm. I have been going to make some out of flat steel banding but I just never get a roundtuit.
