case 480c fuild
hawkengine
05-31-2007 20:23:55
could anyone tell me the type of fuild that goes in the final drive of a case 480c backhoe? It looks like gearoil. also what type goes in the shuttle drive. hy-trans?
bighead
06-03-2007 20:28:56
 Re: case 480c fuild in reply to hawkengine, 05-31-2007 20:23:55
When I worked at a case dealership, we put hy-tran ultra in all the shuttles. Lots of people run Dexron in them, though- and it works fine. The transaxle takes Case transaxle fluid. It looks and smells the same as 90wt gear oil... so I'm not sure just what the difference is. Lots of people run some form of 90wt in them- and it works just fine, but it'll shift easier with the Case transaxle fluid.
Jiles
06-01-2007 07:00:35
Rear transaxle requires gear lube. I use 80W90 in my 480D. You are better off to use Hy-trans in the shuttle, although the manual says you can use Dextron automatic tramsmission fluid.
