gasket set parts help
INCase
05-31-2007 05:13:31
I got a Vickers upper end gasket set for my 800. It is kinda universal as it covers 400, 700 & 800 gas, 400 diesel and 700/800 diesel. Its obvious that there are differeces between the gas intake manifold gaskets and the diesel intakes (400 & 7/800"s were different too). It looks like the exhaust manifold gaskets are the same for all. The parts list shows 4 exhaust manifold gaskets and 4 exhaust manifold ports. 4 of the gaskets fit the ferrels well but the other set of 4 gaskets is a bit larger. Are these the "ports". Are these used with the other gaskets at the same time? The other question I have (sorry this is getting long) there are 6 brass/copper looking washers about 3/4" diameter OD. What are these for/where do they go? Everything else in the kit makes sence and the gaskets line up. Thanks.
