DC Generator
53DC
05-31-2007 05:05:41
Hi guys, I am looking for some help on how to polarize a DC generator. I had the generator rebuilt recently and if I am thinking right I need to polarize it for it to begin charging. I put it back on the tractor and have run the DC a little but it is not charging at all.
Any help would be appreciated. Let me know if there is something else that I need to do to get this thing charging. Thanks.
C. Amick
06-01-2007 09:20:32
 Re: DC Generator in reply to 53DC, 05-31-2007 05:05:41
With the tractor running, check to make sure you are getting power from the battery to the generator. Take the field wire off the regulator and run it to a ground (engine block). If the generator charges, the problem is probably with the regulator. Most new regulators come with polarizing instructions, but I forget how to do it. You should be able to find instructions by doing a search on the Internet.
Mathias NY
05-31-2007 06:21:15
The rebuilt generators I have worked with began generating as soon as they were turning. Here are a couple steps you might try, if you haven't already.
Have you checked all your wiring to make sure everything is hooked up correctly?
Do you have a new voltage regulator to go with the rebuilt generator? Sometimes these go bad.
Have you checked the generator for output with a multi-meter? The ammeter gauge may not be reading correctly.
Good luck.
53DC
05-31-2007 07:03:18
 Re: DC Generator in reply to Mathias NY, 05-31-2007 06:21:15
Thanks for the reply. I have checked with a voltmeter and it is not charging. Everything seems to be hooked up correctly. I hooked it up just like I took it apart. I did not replace the regulator. That will be my next step. Thanks again.
