Case 1030 idle speed set
Dairy Farmer in
05-30-2007 19:01:10
alright i'm tired of having to kill the tractor everytime i want to shut it off. i know i'm sopposed to be able to put the throttle leaver all the way up and it should shut off but mine don't. where and how do i set the idle. also i was curious, my fuel pump says germany on the side. what does this mean? thanks in advance DFinWI
1030 brian
05-31-2007 19:10:41
 Re: Case 1030 idle speed set in reply to Dairy Farmer in WI, 05-30-2007 19:01:10
Check your foot throttle it may be hanging up causing your linkage to not allow "shut off". Good Luck! Brian
Dairy Farmer in WI
06-02-2007 11:11:34
 Re: Case 1030 idle speed set in reply to 1030 brian, 05-31-2007 19:10:41
no it's not hanging up i know because i had to replace part of the fuel line recently and had that little cover off on the right side(from seat) by the brake pedals
do you happen to know how much new brakes cost? mind can't slow down air right now
thanks
df
turbo
05-30-2007 21:04:35
Robert Bosch injection pump. Made in Germany. Very reliable pump.
