antifreeze in oil
ncase
05-30-2007 06:33:59
1949 Case SC
Coolant resevor is going down and oil going up.
Green fluid comes out of oil drain plug or antifreeze in the oil.
Where should I begin looking for this leak?
Klyde
06-03-2007 16:16:46
 Re: antifreeze in oil in reply to ncase, 05-30-2007 06:33:59
Pull the pan FIRST Gasket is cheaper than a head gasket. Rinse the lower end and let it sit a day an see if you got anti-freeze around the bottom of a sleeve (O-ring) or over by the cam (head gasket) hth
C. Amick
06-01-2007 09:31:15
If you pressurize the radiator, keep the pressure very low. These radiators were not made to be pressurized.
TomVAC
05-30-2007 18:31:04
On my VAC I pulled the pan and pressurized the radiator. Found leaks around sleeves. Ended up being block was cracked. Was patched 20 years earlier and it finally gave up. I wouldn't run too long with water in the oil, even if you drain it daily. I ruined the crank doing this.
ncase
05-30-2007 10:09:40
Found when I did my yearly maintance, less than a ouart in one year.But oil has a watery texture
C. Amick
05-30-2007 09:00:38
Are you getting a lot of antifreeze? If it's just a small leak from a seal or gasket, block sealer might solve the problem. If something is cracked, it probalby won't help. I would pull off the oil pan to see if you can tell where the leak is coming from.
37 WC
05-30-2007 07:46:25
The first place I would start would be to pull the head and hope it is a head gasket. I live in Minnesota where it freezes in the winter and crackes blocks if you do not have the proper mix of antifreeze in the system. Good luck.
AllanC
05-30-2007 12:40:02
 Re: antifreeze in oil in reply to 37 WC, 05-30-2007 07:46:25
If these have removable sleeves like the bigger ones do, it is likely leaking around the base of the sleeve. A Bottle of Irontite in the radiator mnay be all that is needed.
