Looking for clutch lever brake pad for 47 Case SC
waltham41
05-29-2007 19:17:10
I am looking for the small brake pad that fits the clutch lever where it contacts the spinning wheel on the right side of the tranny (sorry I dont know what is should be called)
I have not had any luck finding it because I am not sure what it is called
Any help will be most appreciated
Thanks!
C. Amick
05-30-2007 09:03:54
 Re: Looking for clutch lever brake pad for 47 Cas in reply to waltham41, 05-29-2007 19:17:10
Do you need just the pad material or the whole shoe assembly?
waltham41
05-29-2007 23:45:07
Thank you, I will keep that in mind if I cant find a OEM brake pad to rivit on the shoe.
THanks!
LenND
05-29-2007 19:32:47
If it helps any I took mine off of my 900 and took it to a brake shop. THey put new lining and works great.
