case vc brake adjustment
Lee White
05-29-2007 09:21:25
I have a Case VC that has no pedal on the right brake. I looked at the manual on how to adjust the brakes. It was not very clear. Can anyone give me advise. Thanks
Lee White
05-30-2007 08:55:02
 Re: case vc brake adjustment in reply to Lee White, 05-29-2007 09:21:25
Mine must be the early model. There doesn't appear to be adjustment left. Will I have to pull the axle housing off to put new pads on?
Gene Dotson
05-29-2007 10:22:25
VC's used 2 styles of brakes. Earlier models had band brakes and are adjusted by shortening the actuator rod. Later models had disc brakes and are adjusted by 3 buttons on the brake housing. The button is threaded into the housing and uses a 3/4" wrench to turn it. This button is locked in position by a 5/16" bolt through the center. This bolt must be loosened before turning the adjustting button. After all these years it is common for the bolts to be rusted fast to the button. May have to use a torch to heat it to break it loose. The buttons are turned in equally
to reduce the brake clearance.... Gene
