gas in oil
Ralf from MI
05-28-2007 06:48:27
I put this out on the Massey board yesterday and since I collect Case and Massey, thought I'd throw this out here too. Got a MH 33 that I'm getting gas in the oil an don't know why. It's not coolant checked that out, with an up draft carb. I don't understand where the gas is coming from, If anyone has an idea I would greatly appreciate it, thanks
Jim B
07-14-2007 21:59:12
 Re: gas in oil in reply to Ralf from MI, 05-28-2007 06:48:27
Hi Ralf,
We met today at Mark Oberly's auction west of Monroe. It was a pleasure meeting and talking with you.
Did you stay to see that the 830 CK COM Gasser sold for less that the Little Ford with a loader?
I've seen this disparity many times when it comes to tractors of most any color from the 60-70's in the HP range of 50-100. I guess too small for today's real farmers and too big for the average 2-5 acre country estate.
Anyway, as we discussed, I wanted to mention/confirm that the Modern version of this Website/Forum is accessible from the top menu bar shown on a forum page, such as this Case discussion forum. The link is titled: "Modern View". It toggles you to the new version of the forum software. When there you can similarly, toggle back to this old forum by clicking on the "Classic View" link. Entries made on either forum show up in both versions, which is a recent enhancement made during the transition period.
I believe time is marching-on, toward the newer version.
Have a good day. Jim B.
C. Amick
05-28-2007 13:08:28
I could be that the fuel isn't burning properly on the cylinders. You might want try a hotter spark plug. I had this problem a going to a differnt spark plug solved the problem. The carburetor could also be putting too much fuel in.
Jerry W
05-28-2007 12:43:56
Does it have a block mounted fuel transfer pump? Diaphram could be leaking if it does. Jerry
AllanC
05-30-2007 12:37:50
 Re: gas in oil in reply to Jerry W, 05-28-2007 12:43:56
Most likely... the carb is running too rich and the rings are kinda worn, and it's just used for light duty work around the yard. So, main thing is fix the carb and change the oil fairly often.
