430 engine ID
bjr
05-28-2007 05:57:30
The tag on the dash say G-430 and no. 8193100. The engine tag says 2002189. It's a gas engine. It has a front end loader that appears to be original. Does Case ID engine with tractor model only or is there a seperate engine model? I would like to find a carburator kit with float. Also this 3 pt hitch says Eagle Hitch. What's that? It does have a quick detach ends on the lift arms. Are these original. Any general or specific information on this tractor is appreciated. I'm tryin' to help the neighbor get it running again. Will I be fighting a uphill battle getting parts for it? Carb kit and powersteering pump is what I need for now. Sorry for the long post.
james 363
05-30-2007 15:21:11
 Re: 430 engine ID in reply to bjr, 05-28-2007 05:57:30
call case archives they can get you all the info on the tractor you need or check your serial number here in registry, i have there number if you need it.
