DC.. TUF-WORKOUT
J heitkemper
05-27-2007 21:15:23
Run the DC thru quite a tough workout today WITH A 14 FT disc on very rough plowed ground .,NOT SURE BUT after an hour ,I thought i heard a rod knocking , So I shut her dowN.. Oil pressure Good ,Oil level is above full ,,And new 40 wt oil change.. Maybe i was just Hearing things ,,Because it seemed just fine 5 minutes later ,So I ran her gingerly another 10 minutes on smooth ground with no problems , i ALWAYS CONSIDERED THIS MOTOR TO BE TIGHT AND A-1..... .. But I am concerned for this motors wellbeing , probably be a good idea to check bearing clearances and pull shims if necessary , Any Ideas ,m, thanx Jim
DCPULLER
06-02-2007 06:50:11
 Re: DC.. TUF-WORKOUT in reply to J heitkemper , 05-27-2007 21:15:23
If you happen to break the block out around the rear main the oil pressure will drop to around 10 pounds with the clutch engaged and back to 30 when disengaged. run it about half throtle and it will knock if cracked.
Don Rudolph
05-27-2007 21:48:41
Jim,
An old Case dealer friend told me about his latemodel DC that they bought new with a foot clutch and all the other updates. He said he was plowing and working her really hard when suddenly it began hammering inside. When they took it apart the back main bearing casting had broken away from the block. He said it was not uncommon for that to happen in the old days, especially when people pushed them for more power. I hope I'm proven wrong in your case. Don
george md
05-28-2007 12:09:26
 Re: DC.. TUF-WORKOUT in reply to Don Rudolph, 05-27-2007 21:48:41
Don, Back in the 60's my DC had the rear main webbing crack also . I was plowing at the time and it was
a late model with all the latest ft clutch ,live
power, dual valve and eagle hitch. Local dealer was a small shop , so I did the work on it there
but we did not find the crack untill after the
block went thru the hot tank and the crack started to seep the cleaner .Replaced it with one out of a 1939 tractor.Tractor also had an M & W kit at the time. Still have the DC .
george
j heitkemper
05-28-2007 04:37:30
Thanx Don ,COULD BE BAD ,, This is a ft clutcher too ,, It has worked hard lots of times ,,But never as constant as yesterday ,,EVEN THOUGH IT SEEMS NORMAL AFTER THE FACT , i AM CERTAIN THERE IS SOMETHING THAT SHOULD BE CHECKED OUT TO BE SURE, . i think at the very least we will get some plastic gauge and refit the babitted bearings .. SEEING THE POSSIBILITRY OF A BROKEN CASTING ON THE MAIUN BEARING ,, I WISH I HAD NOT STARTED HER AGAIN ,. shucks , jim
Camboted
05-28-2007 16:51:51
 Re: DC.. TUF-WORKOUT in reply to j heitkemper , 05-28-2007 04:37:30
Jim, Even if the worst happened, the good news is that there are plenty of blocks around. I'll even offer you one. DC Tom has a way of strengthening them by adding another bolt, but you'd have to ask him then details. Personally I think you are wasting your time on the rods. If the babbit was bad it would knock all the time. Again i think DC Tom's rod tightening exercise is the best. Keep removing shims until it quits turning freely and then add one very thin shim and tighten. LOL!
L.C.Gray
05-28-2007 08:21:36
Sounds like time for a flashlight and inspection mirror job.
