Battery Cables V Belts - Case Model S
Lee Aanderud
05-25-2007 07:51:28
Does anyone know what length of battery cables I'll need for my '41 Model S? I'm currently 1600 miles away from the tractor and am still gathering parts and would like to try and have everything ready to go when I'm back up in ND to work on it. I'm guessing I'll need 3 cables: 1 - Battery to ignition switch; 2 - ignition switch to starter; 3 - battery to ground. With a 1941, should I use the black negative cable or the flat lead style? I'll have access to a few parts stores, dealerships, and two Tractor Supply stores.
Also if anyone has one of these, what about fan and generator belt sizes?
Thanks.
Lee
C. Amick
05-26-2007 14:03:06
 Re: Battery Cables V Belts - Case Model S in reply to Lee Aanderud, 05-25-2007 07:51:28
John Brillman can probably make you up battery cable and spark plug wire sets (brillman.com). His phone number is on the web site. Use no smaller than a #2 cable for a 6-volt system. Size #1 is better, but a little stiff to work with.
Tom Railsback
05-25-2007 10:26:50
E-mail me directly or call me at (406) 454-8758 as I can't get my reply to take. I have the information you asked for.
