990 Davud Brown
Tom N MS
05-23-2007 18:08:27
Seems that all D Browns will soon be in the scrap pile. Parts are near extinct. Spent(off and on) 2 hours on the phone today trying to locate a crankshaft for a 990 AD4/47A..Prefer new but looks like I must settle for a reground one if I plan for it to ever run again. Reground DB cranks are weak and have a tendency to break like my last one did.
Greg Cigana
06-05-2007 01:41:53
 Re: 990 Davud Brown in reply to Tom N MS, 05-23-2007 18:08:27
Hi Tom,
I checked the Bareco Catalog and they do have crankshafts for the 100mm bore not the 92mm bore that your 990 might have. Your engine type would inficate a pre 1968 model 990 Implematic.
Sorry
Greg
Tom N MS
06-05-2007 04:14:54
 Re: 990 Davud Brown in reply to Greg Cigana, 06-05-2007 01:41:53
Thanks..got lucky and found a new one mot too far from where I live.
Greg Cigana
05-26-2007 16:18:32
Hi All
Check at Bareco (google it) they have new crankshafts and have an outlet in the USA
Cheers from sunny Australia....
Tom N MS
05-26-2007 18:24:37
 Re: 990 Davud Brown in reply to Greg Cigana, 05-26-2007 16:18:32
Thanks. I wll check with them.
richard in nz
05-24-2007 22:14:00
You should not have trouble in a 990 PROVIDED the crank grinder maintains the correct fillit radius when grinding, a lot of them will skimp this as they have to reshape the grinding wheel to do it and it saves them a lot of time and cost. If memory serves me correctly the max grind recommended is 0.010" for Diesels but you can grind further and use the crank in a petrol or kerosene engine. I have been caught out like this before with a less than good machine shop, and I have had cranks ground down to 0.030" U/S with no reliability problems when done correctly. Make shure the fillit radius is maintained by your machine shop.
Tom N MS
05-25-2007 03:17:08
 Re: 990 Davud Brown in reply to richard in nz, 05-24-2007 22:14:00
Thanks. The crank that broke had been turned .040 and had run several years. Not a tremendous amount of running but some of it was ridiculous abuse. After Katrina he pulled huge, whole trees, walking on the rear wheels all the time, dogging it every minute. With sensible, normal use I would have no concern, especially one turned .010.
Thanks again
SteveKy
05-24-2007 19:10:31
Tom if you can't find a new crank ,you can have one custom made .It's not cheap but what is? GOOD LUCK,Steve
Tom N MS
05-25-2007 03:18:38
 Re: 990 Davud Brown in reply to SteveKy, 05-24-2007 19:10:31
I can only imagine how expensive that would be. Good old tractors but not that good to me.JMHO
