Need David Brown Crankshaft
Tom N MS
05-22-2007 19:36:46
Need crank(want new one) for a DB 4/47A..Need front and rear seals, main bearings, rod bearings, pan gasket..Numbers cast in the broken crank are D908453 and stamped above this cast # is G6704. Can someone refer me to a source where I can ge this on order. I am needing to get it back together. Thanks
Elmer
05-23-2007 04:31:48
 Re: Need David Brown Crankshaft in reply to Tom N MS, 05-22-2007 19:36:46
I have one ground .010 under size. Can help with bearings and gaskets. I strongly doubt you will find a new one. [email protected]
