LA Bearing Noise
Jerald Wyssman
05-22-2007 05:48:38
I have bearing noise in my '49 LA. It only makes the noise when the clutch is locked in (engaged). I can push the hand clutch in (driving the tractor) without locking the clutch in and I don't hear the bearing noise. It's just when I push the clutch in to lock it in. It does it at any speed. Some advice says it is the belt pully shaft, others say it's the throw-out bearing. I thought throw-out bearings made their noise when the clutch was disengaged rather than engaged. What's my problem here?
Walt Davies
05-22-2007 10:02:39
 Re: LA Bearing Noise in reply to Jerald Wyssman, 05-22-2007 05:48:38
According my parts book there is no throw out bearing on the LA. It has a Collar, Cone and yoke to engage the clutch. You may have it adjusted to tight try backing off on the adjusting collar a few notches.
There is a bearing on the Clutch shaft that could be bad.
Walt
Jerald Wyssman
05-22-2007 17:07:29
 Re: LA Bearing Noise in reply to Walt Davies, 05-22-2007 10:02:39
Thanks for the response. I'll loosen the clutch a little. It is extremelly tight, feels like your going to break something when you lock it in. That's the way my grand-dad had it before I got the tractor from his estate.
Walt Davies
05-22-2007 18:42:20
 Re: LA Bearing Noise in reply to Jerald Wyssman, 05-22-2007 17:07:29
It should be just enough to snap over over and then test the system by hold the tractor and seeing if it will spin the wheels. If not then move it up one notch at a time until it does.
Walt
