SC adjustable wide front rebuild
SDLars
05-22-2007 05:34:37
I'm working my way on from back to front on my SC and am now trying to figure how to rebuild/take the wear out of the rear pivot point on my adj wide front. What kind of experiences have you folks had?
C. Amick
05-24-2007 09:35:35
 Re: SC adjustable wide front rebuild in reply to SDLars, 05-22-2007 05:34:37
The socket piece on mine was broken. I made a new socket out of a piece of 1-inch thick steel that I had. I cut the steel and drilled the bolt holes and the machine shop cut the depression for the ball. I also added a grease plug.
Glenn F.
05-22-2007 09:25:48
I completely rebuilt the adjustable wide front ends on my SC and DC. I had all 4 king pins spray welded and machined to factory specs. I did the same with the main pivot shafts. I then installed all new bushings. I paid $400 for each of the front ends to begin with.
Going AWF proved to be a rather expensive notion.
Glenn F.
SDLars
05-22-2007 12:49:11
 Re: SC adjustable wide front rebuild in reply to Glenn F., 05-22-2007 09:25:48
How about that ball and socket arrangement on the rear pivot of the SC? I have a couple of ideas but was wondering what others have done.
