430 Case Shifting problems
Dave F.
05-21-2007 09:38:09
Sometimes I have trouble shifting from 1st to reverse or reverse to 1st gear, is there any kind of an adjustment or is this the nature of the beast. Thanks Dave F.
bradley martin
05-24-2007 02:05:52
 Re: 430 Case Shifting problems in reply to Dave F., 05-21-2007 09:38:09
Dave; I would remove the top cover(containing the shift lever) and inspect shift forks, detents, etc. Check the lock screws on the forks are seated in their depressions on the rails and are wired to prevent loosening. Be sure forks are not bent.These are not a synchronized transmission so occasionally the gears don't allign when you shift and require you to let up on the clutch slightly to complete the shift(allowing the input shaft to roll a little ). Good luck.
