oops!
wheat straw
05-19-2007 20:15:36
Well, that's what you get for thinking. Thought the 411B COM engine would bolt up to the old 311 triple range. Now we have two tore down tractors.
Don't have the manuals yet so please give me some help with the com. Never had anything this "modern" before. Is up or down on the lever com. When you push the clutch in, is it kicking it into com or direct drive. I'm not sure whether the com is bad or if it is the direct drive sliping. What does a bad com do? Does it smoke or does it just do nothing? Thanks for any help. We got to get one of them going so we can get into some hay here soon.
Thanks
Wheat Straw
wheat straw
05-21-2007 19:44:02
 Re: oops! in reply to wheat straw, 05-19-2007 20:15:36
Thanks guys. Looked at an IT manual and find it hard to make heads and tails of. Think I'm looking at bad clutches from the way it acts.
Wheat Straw
INCase
05-21-2007 14:51:48
I presume yours isn"t moving or moves really slowly??? THere are a few things that can go wrong. In the COM there is a torque converter that is driven by the engine. This drives a "clutch pack" that is hooked to the transmission. When you push in the clutch pedal the clutches are disengaged hydraulicly via the valve spool conected to the pedal and the torque converter just spins. The direct drive is an additional clutch inside the torque converter that "locks" everything together from the flywheel back again by hydraulics via the valve that is connected to the lever. This give direct drive without slip after you"ve gotten up to speed (plowing or heading down the road). some things can be at fault are seals, the clutch disks themselves, relief valves, a regulator valve (? the one near the clutch valve), poor pump, low/wrong fluid, plugged filter ect. The manual(s) will help you figure things out as far as where to check the hyd pressures. THere is a bit of a trick on the best way to operate these as well so an owner"s manual would help too. others I"m sure will correct me where I"m wrong and add to this as necessary. Good luck.
Texas Sand
05-19-2007 22:28:13
Lever up = COM on a 411
On mine you can"t tell much difference unless it is pulling something, Does your clutch pressure gauge work? If you think there is a problem you might want to check the pressures. (BTW, I am looking for a clutch pressure gauge if you know of one)
I have an owners manual, if you need to know something from let me know and I"ll post it for you.
Phil (NJ,AZ,SASK)
05-20-2007 08:10:28
 Re: oops! in reply to Texas Sand, 05-19-2007 22:28:13
Every time you push the clutch IN the Clutch will reset to Com mode. You only select direct mode when you are in motion
