Case 1370 low trans pressure - powershift
chrisk1500
05-19-2007 20:06:38
Hi Guys,
I have fixed the coolant puking problem this tractor had and now I am on to the next concern.
When idling the tractor trans pressure gauge shows right in the middle of the 'green' bar...once I am in the field working the tractor the needle drops to the border in between the 'green' zone and the 'red' zone...
What is the cause for the loss in pressure? I have just changed the trans filters but that made no difference in the gauge.
Thanks!
corey c
05-19-2007 20:19:46
 Re: Case 1370 low trans pressure - powershift in reply to chrisk1500, 05-19-2007 20:06:38
What range on the powershift are you in when you notice the drop in pressure? You should check for a leak in the powershift. Lower the three point hitch. Idle the tractor, leave transmission in neutral. Raise the three point hitch while shifting the powershift from 1,2,3 and then 3,2,1. See if the hitch stops moving while doing this. The tractor should be sitting still when doing this test.
chrisk1500
05-20-2007 06:25:48
 Re: Case 1370 low trans pressure - powershift in reply to corey c, 05-19-2007 20:19:46
I notice the drop in all three shift ranges and all four gears....my tractor does not have a 3 point hitch...
I am going to top off the TH fluid today and see if that helps...keep the ideas coming!
chrisk1500
05-22-2007 11:53:59
 Re: Case 1370 low trans pressure - powershift in reply to chrisk1500, 05-20-2007 06:25:48
Maybe someone can help me out with something....I don't have the owner's manual for the tractor so I am guessing as to what the trans gauge is trying to say...
Here is how I see it...
red - yellow - green - red
too high - high - good - low
Is that right or is it
too low - low - good - high
