have clutch pressures, what does it mean?
jeff in ri
05-19-2007 15:22:08
Hello, I have a 1960 540c CASEOMATIC with some clutch pressure issues. I bought an I&T manual and a pressure gauge as the book described. Here is wahat I found.
Checked pressure at the T where the gauge connects expected 100-125, found 80-85. Put tractor in direct drive, pressure dropped and recovered quickly as specified. Pushed in clutch, pressure dropped to specified number. Checked pressure at front filter housing, expected 130-225 , found 235. I already checked the pump pressure relief valve and the regulator check valve. Anybody have any ideas?
, jeff
Phil (NJ,AZ,SasK)
05-19-2007 17:28:41
 Re: have clutch pressures, what does it mean? in reply to jeff in ri, 05-19-2007 15:22:08
Dirty Filter! hi-presure going in but low coming out!
Phil (NJ,AZ,SasK)
05-19-2007 17:27:10
Dirty Filter! hi-presure going in but low comming out!
jeff in ri
05-20-2007 05:48:30
 Re: have clutch pressures, what does it mean? in reply to Phil (NJ,AZ,SasK), 05-19-2007 17:27:10
I just changed the filter and used an air hose to blow out the lines going into and thru the cooler in the radiator to make sure they were clear?
Phil (NJ,AZ,Sask)
05-20-2007 07:59:37
 Re: have clutch pressures, what does it mean? in reply to jeff in ri, 05-20-2007 05:48:30
Jeff, The Port on the filter is measuring pressure
through the Filter, and its low, Spec 160-235
@ 1500 RPM, per book
1.Filter
2.Defective relief valve, in pump
3.Worn Pump (plugged pickup)
4.Air in System, low oil level
5 missing or leaking Gaskets
I would blow back the Pump Side to clear any restrictions.
It is also possible that the Control Spool's
are dumping (leaking) or not adjusted correctly.
Hope This Helps,
jeff in ri
05-20-2007 13:27:11
 Re: have clutch pressures, what does it mean? in reply to Phil (NJ,AZ,Sask), 05-20-2007 07:59:37
Hi Phil, The pressure at the filter was 235, this was 10 lbs high according to my book. You say that it is within spec on yours thats good. I opened up the pump and checked the relief valve, and the regulator valve. Both were free ant the springs were in good shape.
I am not sure what I would do with the spools?
Phil (NJ,AZ,Sask)
05-22-2007 11:01:24
 Re: have clutch pressures, what does it mean? in reply to jeff in ri, 05-20-2007 13:27:11
Jeff, The spools have O-ring seals, and you adjust the mechanical clutch linkage such that the spool travel doesn't exceed the Ball detent position.
The Converter Pressure Regulator, mounted on top with temp sensor, also has Dumping Ports and
a Spring (calibrated).
Thats all I Know!
