Early DC starter
Scott KY
05-18-2007 18:17:15
My 39 DC has been changed from the flexable starting control to a push button setup. I would like to put it back to original. Does anyone know what type of cable was used originally? I also need the starter button that sits on top of the autolite starter.
dctom
05-19-2007 10:11:41
 Re: Early DC starter in reply to Scott KY, 05-18-2007 18:17:15
SCOTT, 1931 FORD STARTER SWITCH (J.C. WHITNEY) IS PERFECT MATCH, USE ANY KIND OF CHOKE CABLE TO PULL IT TOM
Scott KY
05-20-2007 15:22:21
 Re: Early DC starter in reply to dctom, 05-19-2007 10:11:41
Hey Tom,
Would that possibly be a 32 model ford switch? I found a website, macautoparts.com that has older ford vehicle parts. Under the catagory "early V8 ford and mercury 32-48" it shows a switch it describes as 4 cyl. hand type model b only. This looks like the switch I need. Could you check that out and see if that is the right switch? I didn't find anything from J.C. Whitney.
Thanks, Scott
Scott KY
05-19-2007 15:01:38
Thanks Tom. I thought you would have an answer.
