900 gear reduction starter
russell1
05-17-2007 19:57:01
I have a 900 that I pull. It has too much compression for the starter with the timing I"m trying to run in it. I need a gear reduction starter for it so It will be easier to start. Does anyone know where to find one. Thanks, russell.
Don Livingston
05-18-2007 05:51:32
 Re: 900 gear reduction starter in reply to russell1, 05-17-2007 19:57:01
Gas or diesel engine? Gas I would suspect. They are small. Don L.
ph 507 433 0073
DKase
05-18-2007 05:51:28
Starter from a 504 power shift should fit. You might have to change the drive gear. If you have a diesel it needs to spin fast to start. If it is gas speed is not as critical.
Camboted
05-18-2007 02:59:24
we modify a Toyota truck diesel starter, add a seal, and cast a different mounting plate. They work great! But unfortunately we are in Cambodia. It looks a lot like the Case skid loader starters for the bigger models. LOL
TxAllisMan
05-20-2007 09:23:19
 Re: 900 gear reduction starter in reply to Camboted, 05-18-2007 02:59:24
Have you tryed an Ignition interupt switch.
If your tractor is like race cars I have been around with high compression you need to kill/interupt the ignition and get it spinning over then turn on the ignition.
It works.
Might try 24 volts.
