Charging system
Denny Hohn
05-17-2007 11:29:00
I have a 47 SC that the charging system is not working it has been converted to 12 volt with a alternator. I had the alternator, voltage regulator and resistor checked, they all tested good. What else is there to ck? I would appreciate and help. Denny H
INCase
05-18-2007 12:50:41
 Re: Charging system in reply to Denny Hohn, 05-17-2007 11:29:00
as DKase said if everything else is truely ok, it must be the wireing. Check this site out. It has some info on wireing alternators/generators. >Link
good>Link luck
DKase
05-18-2007 06:11:53
Make sure the excite wire has power to the regulator, and that the circuit to the battery is complete.
