Big 400 diesel
Bob in Mi.
05-16-2007 21:06:32
Looking at possible buying, are they good as a collector tractor or only a big work horse? This one viberates out of second gear, how serious to fix. Are they worth anything after there restored? Thanks.
bradley martin
05-18-2007 18:18:10
 Re: Big 400 diesel in reply to Bob in Mi., 05-16-2007 21:06:32
Top cover has to come off...also if I remember correctly, you have toremove fuel tank and suspend steering wheel assembly in order to remove top cover. Then it is simply a matter of removing shift rail and replacing spring beneath detent ball. As I said,,,a short day's work to remove repair and replace. Good luck.
Scott KY
05-17-2007 18:19:39
They are not particulaly rare but they do make a nice show tractor. I have one that I use only for shows and parades and one that I use for work and plow days. I think they are one of the best tractors ever produced.
bradley martin
05-17-2007 03:00:38
Coming out of 2nd gear may just be a broken spring under the detent ball in the shift rail..still available from Case and a short day's job.
Bob in Mi.
05-17-2007 18:55:25
 Re: Big 400 diesel in reply to bradley martin, 05-17-2007 03:00:38
Is this something that can be done through the top cover? Can you give me a basic idea of how to go about it? Thanks, Bob.
