Need Information About Case VAI
jjwwrr
05-16-2007 12:42:53
I have a chance to pick up a 1947 Case VAI with stuck motor. The overall condition of the tractor is poor. I do not know a lot about Case tractors. I have worked on Ford N-series and a couple John Deere (40U & 1010). Where can I get history & information on VAI? Does anyone have pictures? Is the VAI worth restoring? I have heard that parts are plentiful & cheap. Any info or advice would be great. [email protected]
Lem
05-26-2007 21:57:40
 Re: Need Information About Case VAI in reply to jjwwrr, 05-16-2007 12:42:53
That VAI is really a cutie. That's what i hope my 1947 VAI looks like in a year or two. I had a VAI as my "personal tractor" as a kid and hay baled my way thru college with it. The front tires on a VAI can be EITHER truck/highway or tractor tires. Most of the special application VAI trzctors had truck tires, but the rest of them had just what you have now, and what both of my VAI tractors had which is the three-rib tractor tire. My big hurdle right now is finding a gas tank. The one i have is badly rusted. Dave
kestrel CT
05-17-2007 17:23:32
third party image
Here's my 1954 VAI after a partial restoration. It's my first attempt working on these machines. I have average experience and average shop equipment but found it to be fairly simple and direct.
Parts no big problem, manuals too, and help from this site- just the best.
I find it to be a strong tractor to haul fieldstone for my stonewall building. It had a loader but I took it off. It was too heavy and cumbersome for my needs.
Good luck.
jjwwrr
05-18-2007 12:19:17
 Re: Need Information About Case VAI in reply to kestrel CT, 05-17-2007 17:23:32
Fantastic looking tractor. Great job. Thanks for your input about these tractors.
Walt Davies
05-18-2007 12:13:46
If you have a VAI (industrial) then you have the wrong front tires on it. Industrial tractors had regular truck tires on the front.
Not that it matters but if you want it correct then you might want to swap with someone for the right tires.
Walt
amo
05-16-2007 17:06:59
Welcome to the old case group. I have a vas which not too many were built, 1579. To get a picture go the the left of this and look under Galleries and then tractor photos and do a search under case vai and you will get pictures. Next go to research and info and go down to production Nbrs. and look under case and then Vai to see number made. Good luck.
jjwwrr
05-18-2007 12:22:21
 Re: Need Information About Case VAI in reply to amo, 05-16-2007 17:06:59
Thanks for the information. I have used this website before, but still learning. Thanks for the tips.
watsonsgotit
05-16-2007 14:07:36
The VAI is simply the Industrial version of the VA or VAC. It is a simple little tractor to work on, much easier than most of those green things. I don't think that you will need any special tools like you will with green ones. Parts are easy to come by. It's twice the tractor of the 8N and worth half to three fourths as much. Early models will not have eagle hitch, later models may. This would make the tractor more valuable.
jjwwrr
05-18-2007 12:24:57
 Re: Need Information About Case VAI in reply to watsonsgotit, 05-16-2007 14:07:36
I know what you mean about working on the green things, seams no two are the same (many parts not interchangable). I think I am going to try my luck with a Case.
