300 hydraulic problem!
Daveminn
05-16-2007 06:22:35
My 300 case tractor used every day for cleaning our dairy barn has started dripping hdy oil out of the half moon plate just under where the motor bolts up at a rather heavy rate,causing the hdy 3 point to have a problem lifting . I add 1 gallon hdy oil every week but upon adding a lot runs out of this plate where the motor bolts up.Anyone have an isea as to what I need to do to fix?Thanks and thanks again for any advice!Dave Ahlgren
BarryfromIA
05-16-2007 19:22:53
 Re: 300 hydraulic problem! in reply to Daveminn, 05-16-2007 06:22:35
Do you have a parts book? There is a pair if seals between the clutch housing and the pump reservoir that can be worn. You would need to split the tractor to get at this. Alway work safely.
