LA parts
sdloy
05-15-2007 18:43:32
Hello I got my new to me LA out Sunday and it runs like a sewing machine, but gets hot in a few minutes. I don"t think it is a compression in the coolant issue, just either a thermostat or water pump issue. Is the thermostat anything exotic, or just a garden variety thermostat. I"ve also been searching a couple vendors and haven"t seen an LA water pump, any ideas on a source? I"m loving this tractor if I can straighten out a few issues. thanks Loy
Walt Davies
05-17-2007 21:37:12
 Re: LA parts in reply to sdloy, 05-15-2007 18:43:32
Go down to wally world and get a botle of (Iron Out) put about a cup full in then run it for sometime about 2 hrs if you can the drain and flush. You can do it over if needed. I did mine once and its been clean every since. that stuff will sure take out the rust.
Walt
Steve-MN
05-17-2007 19:42:32
Just remembered some things. The fan belt was hard to find. Just asked on YTMag & someone out east sells them. Good price. Tractor should run between 180 & 200 degrees. I think Napa had the right thermostat listed, but if not, I put in 190 degree. You don't really need a radiator gasket kit. Just use strips of cork gasket material & overlap 1/8" at all the corners. Use a gasket sealer. Napa had headlight bulbs also. $15 ea.
If you need to replace the cloth spacers that the radiator sits on, you can't get them. I used that black belting material from a combine & band sawed it to the right shape & thickness. Helps to have a couple brothers who are farmers.
Good luck again,
Steve
Steve-MN
05-17-2007 19:28:05
Hi sdloy,
Mine overheated also at first. Took out the thermostat & that helped a lot(on top of the elbow under the tank). Mine's a 49 & the build card lists a thermostat. Never had shutters. Pulled the radiator & had that cleaned. That did the trick. Radiator leaked a tad after cleaning, but put in 1 small bottle of gray liquid stuff(Grey's?) and it's been perfect since. Also put a new thermostat back in(NAPA). Remember to drill an air hole in the thermostat, many of the new ones don't have one. You'll air lock & overheat badly without the hole. I also had the water pump rebuilt since I had the radiator off. CaseIH still sells an operators manual for $17. Handy. Or get an original on ebay for about the same price. Parts manuals & service manuals are a tad harder to find on ebay but they are there.
Good Luck!
Steve
Richard G.
05-16-2007 18:55:00
Forgot to say, I am rebuilding waterpumps for LA's.
Richard
Richard G.
05-16-2007 18:52:14
I had an LA with a thermostat in the elbow from the head to the radiator. Also check to see if the belt is tight.
Drain the the coolant and flush with water for a while. I have seen tons of crud flushed out of the radiators and block.
Richard
Camboted
05-15-2007 22:46:36
If you never rodded out the radiator core 10:1 that is where your problem is. It's a lot of work, but pull it apart and get a long oil dipstick from a junkyard, straighten it out and start poking. You'll be surprised how many of those flues are plugged.
Bob from Australia
05-15-2007 19:39:17
The LA does not have a thermostat. Temperature is controlled via the radiator shutters. The control for the shutters is on the side of the dash.
Overheating could be caused by many things.
The water pump needs greasing daily. It is often difficult to get the water pump off if it needs an overhaul.
The radiator could be blocked with grease and other stuff. If so, remove the radiator (need help to lift it off) then remove top and bottom tanks (bolted on) and clean the tubes with a wire rod, or take it to a radiator shop.
