Frozen engine
jim
12-22-1999 21:00:00
does anybody have any recommendations on a good penetrating oil to free up stuck pistons. I've heard marvel mystery oil is good and would like a few other opinions. thanks
Dwayne Bauersachs
12-26-1999 16:40:29
 Re: frozen engine in reply to jim, 12-22-1999 21:00:00
You need to start with a "dry motor". Then
put water in the piston/sleeve. Wait 2 to 3 days. Then lightly tap the piston with a piece of wood. If it is stil stuck, then let it soak longer and then try again.
What "makes rust desolves rust".
John C.
12-23-1999 06:12:38
I've used a mixture of Marvel Mystery oil and diesel fuel, successfully. The Marvel Mystery oil is supposed to have rust fighters, and the diesel seemed to thin it out a bit. The important thing is to have enough fluid in the cylinder so that it can seep through the rust and around the rings.
