SC with 3 11/16 aluminum piston oil ring
L.Lamp
05-14-2007 20:54:10
I ruined an oil ring when installing a piston in my SC. I bent a rail. I have the rest of the set unused. I bought another set because I could not wait. I have another engine with the same bore size and need an oil ring to make a full set. The rings are Hastings, but any brand will do as long as it is for the 3 11/16" aluminum pistons. If noone has one, I will have to buy another full set. Thanks!!
george md
05-15-2007 08:42:11
 Re: SC with 3 11/16 aluminum piston oil ring in reply to L.Lamp, 05-14-2007 20:54:10
Sealed power (FM) has single cylinder sets and I not sure if they still supply individual rings
or not. I used to get single oil rings for cummins truck engines from them, some of the local diy truckers would by cheap engine kits but they all seemed to have extremely brittle
oil rings so I would order several oil rings to
keep in stock . I think PC also has individual rings available.
If you don't have success holler and I'll get them for you .
george
